No Pulsing Noid
Old Jul 25, 2011 | 11:05 AM
Scuba Sam's Avatar
Scuba Sam
Default No Pulsing Noid
I've got a 99 Ram 1500, 2wd, 5.9L gas, auto tranny with a misfire in jug 6. Put a noid on electric connector and no pulsing; lite just stays on constant. Tested other injectors and all pulsed. I'm guesing PCM lost the injector driver.
My question are: Is this a true diagnosis? Can the PCM be reprogrammed to get the driver back? If reprogramming cannot fix I'm looking for a new PCM.
Any help appreciated.
Thanks
SCUBA Sam
Old Jul 25, 2011 | 11:44 AM
Light staying on constantly means a short to ground somewhere on the wire the PCM uses to fire the injector. Unplug the connector from the pcm, and the injector, and test resistance to ground, see what ya get.
Old Jul 25, 2011 | 08:25 PM
Scuba Sam's Avatar
Scuba Sam
HeyYou,
Thanks for the reply. I should have included in my post that I've done all the mechanical tests; swapping injectors, plugs, wire, new crank sensor, cat, timing chain, cap, button, wires, plugs, O2 sensor and no pooling oil in Plenum. I did check both wires from PCM plugs to injector and no break; gettin about 00.5 ohm resistance from PCM plug to injector connector for both wires. I checked a couple other injector connectors and getting the same 00.5 resistance. Checked ground wire to PCM, clean and good contact. Is it possible the PCM dropped the injector dirver i.e. it just doesn't beleive there is an injector 6?
