68RFE Megalodon
Old Jul 25, 2011 | 07:14 PM
BIGBIRD85's Avatar
BIGBIRD85
Default 68RFE Megalodon
what it the world does this tranny fit? my 97 318? HUH??
Old Jul 25, 2011 | 08:06 PM
aim4squirrels's Avatar
aim4squirrels
Probably the newer CTD's.
Old Jul 26, 2011 | 09:16 AM
BIGBIRD85's Avatar
BIGBIRD85
what is a CDT?
Old Jul 26, 2011 | 10:09 AM
aim4squirrels
Cummins Turbo Diesel. That trans won't bolt to your engine.
Old Jul 27, 2011 | 10:29 PM
MonteC's Avatar
MonteC
68RFE rear wheel drive fully electronic, the six is for 6 speed and the 8 i assume is some type of power capacity rating. The transmission gets is design believe it or not from the Caravan (41TE) transmissions. Same as the 45/545RFE and the 42LE/42RLE.
Old Jul 28, 2011 | 01:13 PM
99dodge318's Avatar
99dodge318
wow this guy knows some pretty interesting facts!
Old Jul 28, 2011 | 09:31 PM
MonteC's Avatar
MonteC
Its tough to try and stay current will all of the new transmissions coming out. Currently there are over 2000 different transmissions on the road.
I have not seen these transmissions come into my shop yet, still to new, they are under factory warranty.
Old Jul 29, 2011 | 12:51 AM
jasonw's Avatar
jasonw
Site Moderator
MonteC is THE resident expert here about transmissions.
Old Jul 29, 2011 | 05:58 PM
MonteC's Avatar
MonteC
I try.
Old Jul 30, 2011 | 12:55 AM
master tech's Avatar
master tech
Site Moderator & Tech
You will most likely found the 68RFE in the 4500 and 5500 diesel trucks, and montec is right, the transmission is almost the same as the 45RFE/545RFE transmission. There was some changes in the 68RFE, One was the manual shift valve. There also another transmission that was put in the 4500 and 5500 diesel trucks,that is AS68RC.
