My ram revs up when I put it in park
Old Jul 28, 2011 | 12:36 PM
thetypezero's Avatar
thetypezero
Dumb answer. But did you make sure you installed the TPS correctly? If you installed it wrong it'll make it idle weird... I did that one time...
Old Jul 28, 2011 | 01:13 PM
johnnybravo59's Avatar
johnnybravo59
Yessir
Old Jul 28, 2011 | 07:33 PM
dhvaughan's Avatar
dhvaughan
since IAC is replaced,and the idle settles down on a throttle/gas pedal tap, i'd guess that either the TB plates are binding open, or the throttle cable is binding open, or the TPS is not sensing the idle position right.
if you remove the air cleaner and sit up in the engine bay, can you repeat the problem and eyeball whats going on, and compare it to how it looks after you bump the throttle.
Old Jul 29, 2011 | 09:54 AM
johnnybravo59
Good thinking, I will climb in there after work today. Thanks!
Old Aug 4, 2011 | 09:31 AM
johnnybravo59
The throttle body did not change position or anything when it was revving high. I'm not sure what else to check??
