possible blown head gasket
Old Jul 27, 2011 | 12:22 PM
sullivanj04's Avatar
sullivanj04
Default possible blown head gasket
Oil when mixed with antifreeze turns white in the radiator doesn't it? I have a greasy build up on the radiator cap and around the fill hole its dark and has th consistency of thick used oil could these be a blown head gasket?
Old Jul 27, 2011 | 12:30 PM
More likely to see coolant in the oil....... (looks a lot like a chocolate shake from McD's.....)
Try this quick test..... When the engine is stone cold, radiator all sealed up nice and tight, start the engine. Squeeze the upper radiator hose, when the engine is cold, and should be fairly soft and pliable, if it is instantly hard, and under pressure, you have a problem.
Old Jul 27, 2011 | 12:35 PM
A_POLVADO's Avatar
A_POLVADO
Well if it is blown dont be stupid like me check your heads real good.I blew a gasket a month ago didnt check my heads come to find out I had a cracked head or burnt valves on cyl #4 now im spending 925.00 on some go fast heads.
Old Jul 27, 2011 | 05:29 PM
sullivanj04
Cool thanks ill try the test tommorow
