engine trouble need help!
Old Aug 21, 2011 | 10:20 AM
  #151
aim4squirrels's Avatar
aim4squirrels
The boost performance timing set is deceiving.
There are 2 marks on the gear that folks mess up. The correct mark is a tiny little dot up in the great teeth that doesn't look like it should be the correct mark, but it is.
Old Aug 21, 2011 | 10:23 AM
  #152
zman17's Avatar
zman17
Retired Moderator - RIP
Funny you should say that, I was just looking through my Mighty Vac manual, and was going to suggest getting a dedicated vac tester. Not the boost gauge.
Old Aug 21, 2011 | 10:24 AM
  #153
DodgeRam5.9's Avatar
DodgeRam5.9
Well I did already set the fuel sync on the engine but the second link you posted is interesting what they are saying is that both timing dots have to be at 12 o'clock on both sprocket?
Old Aug 21, 2011 | 10:25 AM
  #154
zman17's Avatar
zman17
No kidding, that's how you set #1 on a Magnum .
Old Aug 21, 2011 | 10:31 AM
  #155
DodgeRam5.9
Ok I just wanted to be sure I read that correctly. It makes sence but I wanted to be sure I understood that right
Old Aug 21, 2011 | 10:34 AM
  #156
If it starts, and runs, even badly, ignition timing can't be too far off...... I wonder if fuel sync is out of phase though?
Old Aug 21, 2011 | 10:43 AM
  #157
DodgeRam5.9
I was wondering about that I would think that if it is timed wrong at the timing Chain like zman17 said that the engine would not run right at all I had the fuel sync set at a dealer and it was at + 8 to start with and it's now set at +2 and it really made little difference in how the truck runs
Old Aug 21, 2011 | 10:51 AM
  #158
zman17's Avatar
zman17
I could be wrong, but, I think if the cam is off 180 and the distributor is off 180 (when installed assuming the cam is right) it will run. In other words, if you right now you don't touch the dizzy and correct the cam. The dizzy will be pointed to #1 tdc. Not sure I'm explaining that right. Not to mention the fuel sync was set to where the cam is now.
Old Aug 21, 2011 | 11:05 AM
  #159
Does your number one spark plug wire go to the number one spot marked on the distributor cap?
Old Aug 21, 2011 | 11:46 AM
  #160
zman17's Avatar
zman17
You mean like this?
