Air conditioning not working after being charged
Old Jul 29, 2011 | 01:02 PM
jolech550's Avatar
jolech550
Default Air conditioning not working after being charged
I recharged my air conditioning system and still have no a/c. What other tests can I do myself to determine what is wrong. I am leaning towards it being the a/c clutch. I have checked all relays and fuses and they all look and test good. Please help it is very hard on my dog in this heat!!!
Old Jul 29, 2011 | 01:31 PM
Appealing to the dog lovers in the crowd? Probably not a bad plan.
Are you getting 12 volts to the compressor clutch? (engine running, a/c on.) If not:
Put a jumper in the low pressure cutout switch, (not sure if it is up by the radiator, or back by the receiver/dryer on the 98's..... one place or the other.) and see if the compressor runs.
Old Jul 29, 2011 | 02:55 PM
Lone136's Avatar
Lone136
IF you jump it out and it comes on it's still ow on 134a. Also was it vacumed down before it was recharged? YOu have to do a vacum on the A/C if all of the freon was gone. Had to rebuild the A/C in the Wifes Durango and still need to do My Ram, but hers had to be done first. Have to keep her happy so I can be happy.........LOL
Old Jul 29, 2011 | 02:59 PM
chadhager03's Avatar
chadhager03
My a/c hasn't been working in a while because I put the jumper cables on backwards and I guess fried the clutch. You can check to see if the clutch has I think 5 ohms, mine had zero. So I need to replace the clutch but it seems to me like I can only find clutches with compressors. I'm debating if I should go through the effort of getting a clutch from the salvage yard but then who knows if the compressor is bad too. But does your fuse for the a/c clutch relay pop whenever you turn on the a/c?
