still transmission problems
Old 08-02-2011 | 03:38 PM
king_moaoe's Avatar
king_moaoe
alright i found a scan tool from wal mart for 160, what should i do once i have. i checked out shops and they were saying about 90 bucks just to scan it so i figured buy it and split the cost with my friend who needs also.
  #22
Old 08-02-2011 | 04:04 PM
If you scanner can read data, you want to find where it tells you what O/D is doing..... it will be a yes/no, or on/off kind of thing..... see what it says when you think it should be in O/D.
Also look at what it thinks trans temp is.
  #23
Old 08-02-2011 | 08:44 PM
king_moaoe's Avatar
king_moaoe
i took my truck out to a long road to check all my shifts. i was only get two major shifts. trying everything before spending 160 on a tool i might not need.
  #24
Old 08-02-2011 | 10:00 PM
No TCC engage? (shoulda been a little 'shift'...)
  #25
Old 08-02-2011 | 10:03 PM
king_moaoe's Avatar
king_moaoe
at about 45 was the last shift than once got to about 60 it dropped slightly
  #26
Old 08-02-2011 | 10:07 PM
Ok, so, the only thing you are missing is overdrive then. Could just be the solenoid took a dump?
  #27
Old 08-03-2011 | 02:53 AM
king_moaoe's Avatar
king_moaoe
think? that is in tranny above the filter right? is it hard to replace and would i replace anyhting else?
  #28
Old 08-03-2011 | 12:01 PM
O/D and TCC solenoids usually come as a set. (on the same bracket....) Gotta drop the valve body to get them. I vaguely remember a thread that someone didn't have to though???? Unsure there..... I would verify that the solenoid is getting power, and that the PCM is grounding it before replacing it though. Creative use of a volt meter, or test light, should do the trick.
  #29
Old 08-03-2011 | 12:59 PM
king_moaoe's Avatar
king_moaoe
would a scanner do the same thing?
  #30
Old 08-03-2011 | 02:47 PM
If you had one that would show you that data, it would certainly be easier.
