Transfer Case leaking
Old Jul 30, 2011 | 06:51 AM
Stoft's Avatar
Stoft
Default Transfer Case leaking
Hello!
Just bought a 1997 years Ram 1500 Magnum and now it has been starting to leak in the transfer case, see the red ring.. (Not my pic, my transfer case is still on the car)
  • How do I do to take the whole case down and fix the leak?
  • Can I fix it without take the whole case down?
  • Where can I find a Exploded view on this part?
Cheers from Sweden
Old Jul 30, 2011 | 10:42 AM
1nordictom1's Avatar
1nordictom1
I would try to fix the tailshaft leak while on the truck.
Try http://www.drivetrain.com/ for the parts blow up photo.
Old Jul 31, 2011 | 05:07 AM
Stoft's Avatar
Stoft
Ok thanks.
Is it just to pull rear shaft away, take the tailshaft down and then replace the seal and remount?
Nothing more difficult than that?
Old Jul 31, 2011 | 07:08 AM
Stoft's Avatar
Stoft
If i loosen these 4 (?) bolts (in green), can I take it down then and replace the seal?
Thanks
Old Jul 31, 2011 | 11:14 AM
Take the tailshaft housing off first. (the bolts a layer above the ones you are looking at there in green.) Have a look at the snap ring that is supposed to retain the shaft in place, should be right up against the bearing. I don't know if you have to pull that snap ring to get the next layer off there...... Have a look, see what ya think.
Old Jul 31, 2011 | 12:18 PM
Stoft's Avatar
Stoft
Okay, thanks. Will get some new gaskets the fix it.
Old Jul 31, 2011 | 01:50 PM
qlty94's Avatar
qlty94
If the leak is within the red ring its not a rear seal there is a gasket under that tail piece that attaches to the main case.
