picking up my new engine, have some questions
Old Jul 31, 2011 | 01:01 PM
redneck_ram's Avatar
redneck_ram
Default picking up my new engine, have some questions
hey guys, im picking up my new engine next weekend.
its 99 5.9 with 205k on it. my plans are to tear it down and check the heads, and replace parts as needed.
what should i look into? i already have the hughes plenum kit, but i may get the airgap come tax time.
its gonna be awhile til i drop the motor in, cause i still gotta save up for a tuner from hemifever.
so again, what would you all look into, and replace as neccessary?
cant wait to get this done!
Old Jul 31, 2011 | 01:11 PM
Everything.
With that many miles on it, a rebuild is a good plan. Just make sure all the parts you want to re-use are still within spec. I think those are all listed in the service manual. (things like journal size, various bore diameters, etc, etc, etc.....)
Heads like to crack between valve seats. With that many miles, I would be surprised if they DIDN'T have cracks.... my take on that is, don't spend any money on the stock heads, just replace them with better units. There are some low-buck options out there that are vastly superior to the stockers.
things I would replace:
Heads. (for reasons mentioned above.)
Cam.
All bearings.
All gaskets. (naturally)
All freeze plugs.
Oil pump.
Pistons if you have to, just the rings if you can just hone the cylinders nice.
Any other parts that you even remotely suspect of being 'too worn'.
Don't skimp on the machine work either.
Old Jul 31, 2011 | 01:20 PM
redneck_ram
Everything.
Cam.
All bearings.
All freeze plugs.
Oil pump.
i planned on getting the clear water eq's, and i have a decent machine shop about 2 miles from me, that i will take the block to, for the honing. would summit have the piston rings, or should i look elsewhere? this will be my first engine tear down/rebuild and im pretty pumped for it!
Old Jul 31, 2011 | 01:22 PM
Summit will have everything you ever wanted, and more. If you can find a local supplier though, I always advocate that first.... Unless you can get a better price (and don't forget about shipping) or better quality parts.
Old Jul 31, 2011 | 01:23 PM
redneck_ram
i have a cash account at my local advance and get anywhere from 5-45% off, so it would probly be cheaper to start there.
Old Jul 31, 2011 | 04:30 PM
redneck_ram
im going to be going with comp cams 20-746-9 cam, would it be better to go with the regular eq's or the eq monsters? the regular eq's are good for .515" lift and the monsters are good for .600" lift. the cam has a .506" max lift.
Old Jul 31, 2011 | 08:08 PM
I would stick with the regular heads, but, when you order them, see if you can upgrade the valves. .009" is a bit less margin for error than I like to have.
Old Jul 31, 2011 | 09:59 PM
NYJohn's Avatar
NYJohn
Subscribe. Sounds like a cool build take lots of pictures.
