WooHooo I failed inspection. AKA rear brake questions.
Old Aug 3, 2011 | 05:55 PM
  #21
kd5taa's Avatar
kd5taa
@Laramie Thats genius! I'll remember that one lol
And Jack, dont forget to clean and lube the contact points on the backing plate so they dont squeak...
Old Aug 3, 2011 | 07:09 PM
  #22
JackJ's Avatar
JackJ
I finally got tit all back together but the brakes are even worse, I think I may have to adjust them out some more. I tried going it reverse and hitting the brakes and they get better for a split second then go back to sucking. It just sucks having to jack this damn thing up every time.
It is odd though, my left side is missing some pieces, mainly the piece that the adjustment screw from backing off. I don't see that being a problem though.
BTW I got the shoes put on right.
Old Aug 3, 2011 | 07:38 PM
  #23
Adjust your brakes up more if you have excessive pedal travel before you brakes start actually doing something. I usually adjust 'em out till they are just starting to rub. Usually works pretty good.
Old Aug 3, 2011 | 07:45 PM
  #24
gdstock's Avatar
gdstock
I had ugly headlights and they were loose. Found replacements (pair, including turn signals) for $85 on eBay, free shipping. Took about 4 days to get them. Look great, easy install.
