Transmission fluid on ground
Old Aug 2, 2011 | 06:39 PM
15austin's Avatar
15austin
Default Transmission fluid on ground
Was under the truck today getting together a game plan on fuel pump replacement and i saw transmission fluid on the ground. It is comming from where the transfer case and transmission bolt together. Question is would it be fluid from the transfer case or transmission. If i keep it full of fluid i can still drive it until i can fix it.
Old Aug 2, 2011 | 06:42 PM
Check both, see if either are low. It don't take much fluid to make a BIG mess...... (they both use the same fluid, ATF +4)
If it ain't leakin' bad, just monitor fluid levels, and fix it when you have time.
