need some help with 96 ram
Old Aug 4, 2011 | 10:42 PM
gonehuntin817's Avatar
gonehuntin817
Default need some help with 96 ram
Got a few trouble codes from it today. One was 23 which I think is intake air temp sensor. If so where is this located. Next was 27. This one I don't know what it is. So if someone could help me out there I would appreciate it.
Old Aug 4, 2011 | 10:56 PM
aim4squirrels's Avatar
aim4squirrels
IAT, intake air temperature sensor
Passenger side, halfway up the front of the intake manifold behind the alternator. Brass fitting with a larger plug sticking in it.
Old Aug 4, 2011 | 10:57 PM
gonehuntin817
Ok. Thanks. Is there anyway I can just clean it or should I just replace it?
Old Aug 7, 2011 | 12:00 PM
gonehuntin817
Ok I got the IAT replaced. Now just need to fix that code 27
Old Aug 7, 2011 | 12:18 PM
code 27 on an OBDII system??
Old Aug 7, 2011 | 01:38 PM
charlie1935's Avatar
charlie1935
Probably counting the flashing light on the dash.
Old Aug 7, 2011 | 01:55 PM
I can't find charts for those anywhere..... link??
Old Aug 7, 2011 | 02:07 PM
xjarhead69's Avatar
xjarhead69
I would double check that 27 code i dont find it anywhere.
Dave
Edit found it http://dodgeram.info/Engine-Gas/OBDI/pcm_fault_code.htm
Old Aug 8, 2011 | 06:28 PM
gonehuntin817
Yep. Does anyone know how I go about fixing this issue?
Old Aug 8, 2011 | 06:43 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Make sure the plugs are on the inj's tight and check the harness for damage to start with.
