Bad window motor
Old Aug 5, 2011 | 12:34 PM
kingtip's Avatar
kingtip
Default Bad window motor
Can anyone explain to me how to remove window motor and regulator assembly with the window stuck in the up position. I went and bought a service manual but it didn't explain how to remove with the window up.
Old Aug 5, 2011 | 02:25 PM
JackJ's Avatar
JackJ
It may be different but I changed one on a Tiburon about 3 weeks ago and the window was stuck up, I pulled out the regulator and motor held the window though so it did not fall.
Old Aug 5, 2011 | 08:05 PM
Use some duct tape to hold the window in place, once you have the rivets that hold the regulator in place removed, just slide the little wheel out of the track it runs in under the window.
