Ring Gear Backlash Adjuster
Old Aug 7, 2011 | 12:06 AM
Arde's Avatar
Arde
Question Ring Gear Backlash Adjuster
Have found it necessary to make a tool to loosen the ring gear backlash adjusters on my 9.25 rear end.
Does anyone know the size of nut or bolt that will fit in the adjuster? Plan on using a nut or bolt, piece of rebar, and a cheap socket with a little bit of welding to make the tool.
Just missing this one critical piece of info.
Old Aug 7, 2011 | 12:35 AM
DukesOfHazzard's Avatar
DukesOfHazzard
http://www.pirate4x4.com/forum/showthread.php?p=8208211 check this out.
Old Aug 7, 2011 | 12:39 AM
merc225hp's Avatar
merc225hp
I think it's 1". The tool is in the shop;I will check for you in the morning to make sure. After reading the above i guess i don't have to.
Old Aug 7, 2011 | 01:43 AM
Arde's Avatar
Arde
Question answered!
Appreciate the replys. Well time for some sleep, get up and get with it.
Old Aug 7, 2011 | 08:28 AM
charlie1935's Avatar
charlie1935
They used to be called "spanners".
