Trans. Service?
Old Aug 9, 2011 | 07:47 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Default Trans. Service?
Well, my trans. has been leaking and it's gotten worse.
So it's going to be time to take it to the shop to have the seal between the trans. and the t-case replaced.
So, I am thinking I might as well have some other trans. maintenance done.
So far I have:
Drain and refill t-case (obviously)
Drain, change filter, adjust bands on trans.
Replace/clean trans. cooler check valve (I know, I know)
Anything else?
Also, how much ATF will I need?
I am going to see if I can bring my own fluid, that way I KNOW I have the right stuff in there.
Thanks for any input.
Old Aug 9, 2011 | 08:32 PM
JackJ's Avatar
JackJ
I found this in the DIY section at the top of the page.
Automatic Transmission, 46RE Initial Fill..........4.1 quarts
Automatic Transmission, 47RE Initial Fill..........4.1 quarts
Automatic Transmission, Total Fill
4 speed 46RE..........11.7 quarts
4 speed 47RE..........17 quarts
Manual Transmission, NV1500.................................4.7 pints
Manual Transmission, NV4500.................................8.1 pints
Manual Transmission, NV5600.................................9.6 pints
Manual Transmission, NV3500 4WD..........................4.3 pints
Manual Transmission, NV3500 2WD..........................4.9 pints
Differential, 4WD With Dana 44 Front (216-FBI).........4.8 pints
Differential, 4WD With Dana 60 Front (248-FBI).........8.5 pints [3]
Differential, 2WD With Dana 60 Rear (248-RBI)..........6.4 pints [2]
Differential, 2WD With Dana 70 Rear (267-RBI).............7 pints
Differential, 2WD With Dana 80 Rear (286-RBI)..........6.8 pints [4]
Differential, 4WD With Dana 60 Rear (248-RBI)..........7.5 pints [2]
Differential, 4WD With Dana 70 Rear (267-RBI)..........7.7 pints
Differential, 4WD With Dana 80 Rear (286-RBI)........10.2 pints
Transfer Case, NV241HD W/ PTO..........................10.4 pints
Transfer Case, NP231, 233....................................2.6 pints
Transfer Case, NV242, 244....................................2.8 pints
Old Aug 9, 2011 | 10:43 PM
dhvaughan's Avatar
dhvaughan
trans fluid and filter change on my 01 takes 6-7 quarts, including extra cooler and filter.
t-case takes 1 quart.
i would remove the check valve or drill it out.
Old Aug 10, 2011 | 09:08 AM
dodge dude94
So basically an "Initial Fill", would be a trans. service?
So I am looking at 5 quarts total?
What will happen when I take the check valve out?
I know trans. fluid will come out the cooler line, but do I have to do anything special? Or can I just drill it out like you said?
Does it increase fluid flow any? I know if it's clogged it will.
Thanks guys!
Old Aug 10, 2011 | 09:13 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You need to remove the hose completely to drill out. So you need the line disconnect tool.
Old Aug 10, 2011 | 09:20 AM
dodge dude94
^Guess that'll wait will next summer when I might have time.
lol
Thanks, zman.
Old Aug 10, 2011 | 09:35 AM
zman17's Avatar
zman17
The tool is like 5 bucks and it shouldn't take more than a half hour.
Old Aug 10, 2011 | 10:03 AM
dodge dude94
^Oh, I would figure out some way to make it 2 hours.
I always do.
lol
Old Aug 10, 2011 | 10:04 AM
zman17's Avatar
zman17
Lol,
Old Aug 10, 2011 | 10:12 AM
dodge dude94
Hey, I got a tune up out of it one time!
