Another transmission question...
Old Aug 11, 2011 | 09:55 AM
bigdodge97's Avatar
bigdodge97
Default Another transmission question...
97 ram 1500 4x4 5.9L
little history on the truck. Its got 300,000 miles on it. Its lifted 6" with 36 bfg's A/T. Its on its third transmission. On this last go around I had a transmission cooler run from the front and it really seemed to keep the heat down. Ive had this one for 60,000 miles.....sooo my issue is about 16 months ago I finally had the plenum gasket blow and it was a catration of power. To make things worse while i was trying to diagnose the engine standing in the engine bay my foot loosend one of my tranmission lines...so the next drive i took it on ended up dumping the transmission fluid all over the street. At that point i put into storage until just last month. Ive already fixed the plenum and did a full tune up while i was in there and the motor sounds like new and runs smoother than ever. when the incedent happened i filled the transmissin up with fluid after i realized it dumped it self on the street. so when i went to drive it yesterday i added a bottle of lucas transmission fix to top it off. Took it for a spin and success! It drives and switches into all gears as well as reverse. Im extremely happy that it even drives as well as it does at this point.
But it feels like im its not as "catchy" as it used to be in terms of acceleration. I remember before that i could easily peel out if not carefull...not so much now. Its almost like i would have a hard time towing something. So ive already decided that im going to flush it tomorrow and pull the pan to replace the filter. Is there anything else i should replace while in there? Ive read that there is a particular solinoid that goes out often on these and will affect shifting and what not.
Thanks for reading my essay
Old Aug 11, 2011 | 10:39 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Damn dbl. post.
Old Aug 11, 2011 | 10:40 AM
zman17's Avatar
zman17
Get the Lucas out of it. ATF +4 only. You can remove the Governor Solenoid and clean it as well. Adjust the tv cable too, https://dodgeforum.com/forum/2nd-gen...-in-trans.html
Old Aug 11, 2011 | 10:58 AM
bigdodge97's Avatar
bigdodge97
The TV cable sounds simple enough. As far as cleaning the solenoid do you have any suggestions? would i be better off buying a new one and just replacing it?
Old Aug 11, 2011 | 11:02 AM
zman17's Avatar
zman17
You are really not having symptoms of it being bad, I would just clean it. One thing you should do is add one of these, Name:  DSCF0614.jpg
Old Aug 11, 2011 | 12:01 PM
bigdodge97's Avatar
bigdodge97
Yea i will definatly look into that. Also I noticed this while under my truck yesterday and snapped some pics....Im thinking is a vacuum line for my 4 wheel drive but im hoping others can clarify.
here it is coming down from my transmission, Its circled to indicate the broken line
here is where it connects on the front axle
and here is where the stick or branch on steriods broke the steel line like a toothpick
would this broken line cause my 4x4 to not work? probably 2 years ago i fried a solinoid of some sort while in 4x4 trying to escape a muddy ditch. Im thinking more and more this was the main cause.
Old Aug 11, 2011 | 12:13 PM
zman17's Avatar
zman17
Yep, that's for 4wd. The CAD assembly on the axle. http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Aug 11, 2011 | 12:26 PM
bigdodge97's Avatar
bigdodge97
Thanks for the link. Guess i will fix that while under there too. As far as the govenor solinod goes how would you go about cleaning/testing it?
Old Aug 11, 2011 | 12:33 PM
zman17's Avatar
zman17
Testing it requires expensive equipment. Cleaning it requires some carb cleaner.
