Please Help: Broken Spark Plug!(w/pics)
Old Aug 11, 2011 | 11:25 PM
beamwalker's Avatar
beamwalker
Unhappy Please Help: Broken Spark Plug!(w/pics)
While doing plenum repair/tune-up on my 1999 5.2 1500 I broke a spark plug hex head off at the block. Luckily, the porcelain came out intact.
The washer portion below the hex including threads and electrode are intact. The washer head is a hair off the block face.
Has anyone dealt with this that could offer any advice?
Here is a pic down the heat boot and one of the other plugs to give you an idea of what I'm talking about.
Old Aug 11, 2011 | 11:47 PM
jrp267's Avatar
jrp267
Soak it with a good penetrating oil over night then use an easy out. Pray a little too.
Old Aug 12, 2011 | 11:44 AM
Pronk's Avatar
Pronk
Yeah an easy out seems like your best option, just soak it in pb blaster for awhile first
Old Aug 12, 2011 | 11:54 AM
And don't break the easy out......
Squirt it when your chemical penetrant of choice, use a long half-inch extension, and tap on it a little bit. (the vibrations help the chemicals penetrate. ya don't have to hit it hard.) Do that a couple times, and let is soak for a couple hours at least...... Good Luck. I hate those problems....
Old Aug 12, 2011 | 06:54 PM
beamwalker's Avatar
beamwalker
Thanks guys! Went with Seafoam Deep Creep and EZ Out. Success!
Old Aug 12, 2011 | 07:17 PM
dhvaughan's Avatar
dhvaughan
congrats. that's a pucker up situation.
Old Aug 12, 2011 | 07:18 PM
Now there is an accurate statement.....
Old Aug 12, 2011 | 08:53 PM
BIGBIRD85's Avatar
BIGBIRD85
just curious................how long were those plugs in there? i have never had mine look like that
Old Aug 12, 2011 | 09:09 PM
Hahns5.2's Avatar
Hahns5.2
Rust belt...
Do yourself a favor and rid of those stupid heat shields. Also, cameras have a "macro" function
Old Aug 12, 2011 | 10:28 PM
JSTMoto's Avatar
JSTMoto
Make sure to use some anti seize on the new plug threads before you install them.
Makes removal a breeze. I bought a tube of the Permatex anti-seize and it lasts quite a while for the average Joe.
