underdrive pulley belt length
well, then i guess ill just order the crank pulley..... is it a 95" belt with th a/c pulley mixed in, or without the a/c pulley? i bypassed my a/c compressor because the bearing went. im running a 90" belt right now, so an 89.5" belt then? because the stock belt is 95.5"
ordered my crank pulley tonight! hopefully ill see it friday, if not itll be here monday! still got to figure out belt size, ill probly just do the string trick, rather play the guessing game. cant wait to get it!
for those that have the crank pulley, is it a 6 or 7 rib pulley?
Stock belt on my truck was a 97.5 and I dropped down to a 95.5 size belt. Ran both alt and crank pulley for a bit...( my kit came with a larger alt pulley too so it's not just Hughes)
Volts were to low at idle so I took off the alt pulley, still have the crank on there....never changed belt size
well i have a 90" belt on there now because i bypassed my a/c compressor, so i might be able to get away with the 88.5 belt that advance offers. im still going to do the string trick to be safe, ubless someone can chime in that has the u/d pulley that doesnt have a/c.....
