Heat/AC Problems
Old Mar 14, 2012 | 12:39 PM
nicktw25's Avatar
nicktw25
Default Heat/AC Problems
I have a 2001 dodge 1500 v8 5.2. I noticed today that my truck blows heat if the thermostat is pointing at the red(heat) even though the fan is turned off. It blows cold air when the thermostat is pointed at blue(air) and the fan is turned off. It really starts to blow hard once i hit 45-50 mph.
Any help would be great!!!
Old Mar 14, 2012 | 12:46 PM
Normal. The heater gets its air from the cowl at the base of the windshield, when the truck is moving, that becomes a high pressure area, so, naturally, the air wants to go to a lower pressure area. Easiest way is into the cab.
Old Mar 14, 2012 | 02:52 PM
nicktw25's Avatar
nicktw25
Well then why does the air coming in my cab change temperature when i put it on hot or cold?
Old Mar 14, 2012 | 03:06 PM
Because it is taking the same route that it normally would if it was being moved by the blower motor..... there is always some air flow....... (when the truck is moving.) the blower just moves it more enthusiastically.
Old Mar 14, 2012 | 08:10 PM
Ramzy's Avatar
Ramzy
yep...completely normal. All off does is turn of the blower motor.
