cant remove o2 sensor
Old Aug 12, 2011 | 03:54 PM
tatitup8's Avatar
tatitup8
Default cant remove o2 sensor
i got a new NTK sensor but i cant seem to loosen the old one up and take it off? i just sprayed some PBuster on it and ill go back and try... anyone have any tips?
Old Aug 12, 2011 | 03:56 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Start the truck and get the pipe hot then try.
Old Aug 12, 2011 | 04:04 PM
SilverSS's Avatar
SilverSS
breaker bar and O2 socket
Old Aug 12, 2011 | 04:11 PM
tatitup8's Avatar
tatitup8
ill try turning it on, im using a vice grip because i dont have a big enough socket/wrench
Old Aug 12, 2011 | 04:15 PM
UnregisteredUser's Avatar
UnregisteredUser
Kinda sorta what's already been said, but a bit different: Get yourself a can of CRC FreezeOff and a butane torch. Disconnect the harness so there's no danger of melting it, heat the sensor bung until it's quite hot, then blast it with a ten to fifteen second shot of FreezeOff. Then take the sensor wrench to it.
You might find that it's rusted clear to hell. If so, tap the wrench around carefully with a hammer, near the sensor rather than out at the long end. After if moves a bit, turn it back in, then back out again, and if it hangs up do the tapping/in/out thing at the sticky spots. If it hangs up badly, repeat the torch/FreezeOff trick.
This method works on most stuck things most of the time. Just don't vent frustration on the part -- slow and steady gets the job done.
Old Aug 12, 2011 | 04:27 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
^^ I went through that with my Cavalier but didn't know of using the freeze off. I heated it thoroughly and removed it. The threads on the sensor were flattened upon removal, but the good news is the threads on the bung were OK. I installed the new sensor with Anti-Seize on the threads.
Old Aug 12, 2011 | 04:32 PM
tatitup8's Avatar
tatitup8
do yall know what size exactly the nut is instead of getting a whole o2 sensor kit??
Old Aug 12, 2011 | 04:34 PM
zman17's Avatar
zman17
7/8" ... What are you trying to use now?
Old Aug 12, 2011 | 04:44 PM
tatitup8's Avatar
tatitup8
just one of those adjustable pliers.. :/ dad has the big tool box at work..
Old Aug 12, 2011 | 04:47 PM
zman17's Avatar
zman17
If the nut part is getting rounded, use a plumbers wrench or a large pair of vise grips. And start the truck and heat the pipe up like I said.
