removed the cat, now I have some issues need help,please
Old Aug 13, 2011 | 12:43 PM
I would have a look at all the connectors at the trans, t-case, and assorted sensors down there, and check the harnesses as well. Unplug, inspect, and plug back in everything. Clean what needs it, a dab of di-electric grease on the connectors won't hurt ya either.
Old Aug 13, 2011 | 12:55 PM
sidewayzz's Avatar
sidewayzz
thanks will do!
Old Aug 13, 2011 | 02:42 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The 1762 code has nothing to do with the o2 sensor. Did you reset the pcm?
Old Aug 13, 2011 | 02:57 PM
sidewayzz's Avatar
sidewayzz
yes I did clear the codes with the SCT and unhooked the battery. I cant understand why I got that code either. But it happened after I messed with the cat
Old Aug 13, 2011 | 03:07 PM
zman17's Avatar
zman17
Could be just a coincidence or you hit a wire or a connector on the tranny is loose as HeyYou has suggested.
Old Aug 13, 2011 | 04:15 PM
sidewayzz's Avatar
sidewayzz
I just came in from checking all electrical connections.All seems well there.I am at a loss. Its gotta be something that I did wrong.
Old Aug 13, 2011 | 04:24 PM
zman17's Avatar
zman17
Is the code gone for the o2 sensor? If it is, then like I said, it's total coincidence. If not, the only thing the 2 may have in common is a ground wire.
Old Aug 13, 2011 | 04:50 PM
sidewayzz's Avatar
sidewayzz
just came back from short drive its throwing 0037 and 0138.Do you think I should change both O2's? it runs good. Seems to have more power than before.
Old Aug 13, 2011 | 04:54 PM
zman17's Avatar
zman17
So now the 1762 code is gone?
Old Aug 13, 2011 | 04:59 PM
sidewayzz's Avatar
sidewayzz
Yes 1762 is gone, still getting the others though. Thanks for your help. Thinking 1762 must have been a coincedent also.
