Anyone running E-fans bolted
Old Aug 15, 2011 | 05:55 PM
  #31
Joey Buentello's Avatar
Joey Buentello
the probe is a threaded rod that does nothing but hold the thermostat to the radiator. Or did you think that tube held some mystical temp reading powers.
Old Aug 15, 2011 | 06:05 PM
  #32
drewactual's Avatar
drewactual
you aren't very smart, are you?.. mystical temperature reading powers.. hmm..
quoted from http://www.omega.com/prodinfo/rtd.html ...
Resistance Temperature Detectors / RTD / RTDs
What is a Resistance Temperature Detector? Resistance Temperature Detectors (RTD), as the name implies, are sensors used to measure temperature by correlating the resistance of the RTD element with temperature. Most RTD elements consist of a length of fine coiled wire wrapped around a ceramic or glass core. The element is usually quite fragile, so it is often placed inside a sheathed probe to protect it. The RTD element is made from a pure material whose resistance at various temperatures has been documented. The material has a predictable change in resistance as the temperature changes; it is this predictable change that is used to determine temperature.
why don't you tape the probe to the exhaust pipe? that will trigger the fan too... until the tape melts.. or, maybe, use some screws and mount it to the top of your tire, after screwing about four anchor bolts to the tire itself? you could just stick it in your gas tank, with the coiled end stretched out and attached to your coil.. that way is certain to eliminate your problem.. and ours too..
Old Aug 15, 2011 | 06:50 PM
  #33
Gary-L's Avatar
Gary-L
Veteran: Navy
^^ Pay heed to Drew and all of the statistical, analytical, and sheer gobs of VooDoo data he hurls your way. Trying to tactfully argue against it is like whizzing INTO a hurricane.
Old Aug 15, 2011 | 07:15 PM
  #34
drewactual's Avatar
drewactual
Vdub, I certainly ain't that smart.. I have a long way to go before I would consider myself knowledgeable about these rigs.. that's for absolute certain..
but:
I CAN read directions, and I'm not afraid to ask or search for answers.. I'm not even opposed to experimenting to figure something out if it isn't a critical system I'm messing with..
this dude though? he wants to make a slight and take an air of superiority on an internet message board? first off, he 'plumbs' the floggin' heater core line and thinks THAT will give him an accurate temperature reading, and then argues that his set-up is correct in it's installation.. then he makes a comment about someone (me) thinking a temperature element is some sort of witchcraft, and that the probes sole function is to attach the thermostat to the radiator? ?????????? Thermostat to the radiator? with the probe????
The good thing about this is, I can simply ignore him, and read about his destroying his truck whilst I eat popcorn and drink a beer.. this crap is good entertainment while it storms outside, if nothing else.
Old Aug 15, 2011 | 07:29 PM
  #35
jasonw's Avatar
jasonw
Site Moderator
I know we get frustrated with each other sometimes guys, but lets tone it down a little bit please.
Old Aug 15, 2011 | 08:13 PM
  #36
Joey Buentello
but:
What have you done to your truck lately? Btw I run a Derale Dual fan kit which i can buy a rad temp prob for, which does nothing but hold a thermostat to the radiator. Here is a link to another forum , I have a bbq pit to tend to. Peace out foo.
http://ls1tech.com/forums/conversion...-coming-2.html
Sucks that most of the people posting on this site are d bags. Squirrles and hey you ROCK!! Thanks for the info.
Old Aug 15, 2011 | 09:00 PM
  #37
aim4squirrels's Avatar
aim4squirrels
I'm not envisioning the probe and holder, can you post a link to a pic of it?
Old Aug 16, 2011 | 01:23 AM
  #38
jasonw's Avatar
jasonw
Site Moderator
Not to jump on you here, but how exactly is this toning it down?
Old Aug 16, 2011 | 10:18 AM
  #39
zman17's Avatar
zman17
Retired Moderator - RIP
The dude in that link you gave, that provided the picture has a problem(defective unit) with the thermo, that's why you are confused. Even just the tip of the probe should be able to be put in,on or near heat and if working correctly will provide a signal.
Old Aug 16, 2011 | 10:30 AM
  #40
aim4squirrels
Giggle.
