FUEL PUMP AND AIR CONDITIONER QUESTIONS
Old Jul 18, 2005 | 04:40 PM
jrwpmw's Avatar
jrwpmw
Default FUEL PUMP AND AIR CONDITIONER QUESTIONS
98 Dodge RAM 4x4 1500
Two questions - and thanks in advance.
1) I hear the fuel pumps commonly go out after 100,000 miles? Is this true and should I have it replaced as a safety precaution?
2) I have a slow A/C leak, I'm told it may be the evaporator which is a $1,000 job. Does that sound right to you?
Old Jul 18, 2005 | 06:14 PM
Capepowder's Avatar
Capepowder
Default RE: FUEL PUMP AND AIR CONDITIONER QUESTIONS
Can't comment on the fuel pump. Never had any issues with mine (94 ram 1500 with 168,000 miles).
I can suggest adding a R134a coolant with "stop leak: in the ac system. Worked for my leaks. Cost about 15.00 witih a hose to add it yourself.
Good Luck
Bob
www.capecodpowdercoating.com
Old Jul 19, 2005 | 12:13 AM
2kramquad's Avatar
2kramquad
That's a little high for an evaporator...I had mine done a the dealership and it was less than $800.
Old Jul 20, 2005 | 08:26 PM
cnewt15's Avatar
cnewt15
the mechanic I used to work for said he would do it for 250. That is what the book listed.
Old Jul 20, 2005 | 10:31 PM
moparman81777's Avatar
moparman81777
My fuel pump went at 149k
Old Jul 21, 2005 | 10:54 AM
Flynbryan19's Avatar
Flynbryan19
Mine went out at 60k. :\
Old Jul 21, 2005 | 01:22 PM
moparman95's Avatar
moparman95
My fuelpump went bad at about 110,000. My tank was 3/4 of the way full so I opted to take the bed off instead of dropping the tank.
