Truck randomly stalls - 'No Bus'
There isn't one. The crank sensor you'll want some universals and different length extensions. A small mirror to see back there will help also. It's a PITA. As far as the Cam sensor goes, that is a matter of removing the distributor cap and rotor. If you've done that, then you know thats a pita too.
Well I changed out the crank sensor yesterday, not all that successfully.
That crank sensor is a pain in the **** to get at.
My wrist is all slashed up from the heat shield. It was tuff to get my hands in there, I was really working blind.
Anyway, changed the sensor out and now it throws a P1391 code, 'Interim loss of CKP'?
Doesn't run well at all.
I am going to go back in and make sure it's in the grommet hole correctly, I can't see in there only by feel, or swap back to the original.
What a bitch, I removed it blew out the hole, electric greased the connector and re installed yesterday. Took me half the time now that I know how to get in there.
Test drive was good, but when I went to run a few errands, it threw the code and ran like crap again right away.
I am going back to the original sensor, today after work, seems the PCM has no problem seeing the signal and throwing a code if it doesn't like what it sees. I am going to have to assume this sensor is not the source of the mysterious die while driving issue I am trying to solve.
I'll wait for my new PCM to arrive this week and try that.
