Valve Body help
Old Aug 19, 2011 | 03:47 PM
ionakana's Avatar
ionakana
Default Valve Body help
Sorry so long. I had the trans in my 01 5.2 rebuilt last summer. The trans has been rebuilt once before. The first time around 95K and the second when I did it at 191K. The shop that did it is very reputable, they've been in business for 30 years with their 3 mechanics being there 20, 25, and 28 years. Our company has used them for the last 25 years with no problems, that's how I found them.
Since the rebuild the trans has had to have the valve body replaced twice, that's within 10K miles. They installed a brad new valve body the second time. Now it's been another 5-6k miles or so and I believe the valve body is going out again. I hear a brief sucking sound when I hit the gas, I heard it before and thought I was hearing the throttle body but it went away when they replaced the valve body. It's come back so I know the VB is probably going out again. The trans also seems to shift hard when I come to a stop. I assume it's shifting back to first.
What could be causing this? The trans shop is standing behind the trans, they even extended the warranty on it from 2 years 24k to 5 years 50k because of the trouble. They've rebuilt hundreds of these and have never seen this before, they open the trans up and find nothing but a bad VB. I'm tired of this, it's becoming a hassle and before I take it back a third time has anyone had this problem?
Old Aug 19, 2011 | 04:05 PM
I have rarely heard of a valve body going bad...... let alone two within a few thousand miles of each other. There has to be something else going on there, that is causing them to fail. I don't have the faintest idea just what that would be though.... Any idea what is 'bad' on the ones that have failed??
Old Aug 19, 2011 | 04:11 PM
ionakana's Avatar
ionakana
They didn't say, they replaced the valve body and that solves the problem apparently for 5k miles. The problems I had were going into passing gear. When I floor it to pass someone instead of going to passing gear it goes in to neutral. It has that sucking sound as well that has come back but I have yet to be able to make it go to neutral. It would also only do it if I was say "changing lanes" at the same time. It would never do it driving straight.
Old Aug 19, 2011 | 06:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Maybe the TC is falling apart. Needs a good one. And when it is falling apart, it's clogging up the VB ? Or maybe it just needs a better Governor solenoid? Just throwing it out there. Where is MonteC when you need him. LOL
Old Aug 19, 2011 | 06:39 PM
Yeah, no doubt zman!
Try replacing the governor pressure sensor, with a better unit than what dodge puts in there. The stock ones are know for becoming saturated at WOT, and not working correctly........
Old Aug 19, 2011 | 07:57 PM
aim4squirrels's Avatar
aim4squirrels
If the line pressure is too high it'll warp the valve body, should be 1 psi per 1 mph in third gear. Lock put od and drive it up to 60mph, should be right near 60psi need a scanner to read it though.
Over torquing the vb can also cause weird problems, torque is only 100 inch/lbs.
Old Aug 20, 2011 | 02:44 PM
ionakana's Avatar
ionakana
Thanks for the help, I'm going to ask about what everyone suggested, they also added a trans cooler when they rebuilt it. Could that be a problem?
Old Aug 20, 2011 | 02:49 PM
zman17's Avatar
zman17
No, the trans cooler will only help the tranny.
Old Aug 20, 2011 | 04:16 PM
xjarhead69's Avatar
xjarhead69
Borg Warner makes a better one, anyone know the number for it?
Thanks Dave
Old Aug 20, 2011 | 04:37 PM
zman17's Avatar
zman17
Yea I got it, hold on a minute.
