Can you hear your tranny shift?
Old Aug 19, 2011 | 11:19 PM
tweav88's Avatar
tweav88
Default Tranny makes noise when it shifts
1994 dodge ram 1500 5.2l 46rh
So this isn't a problem or anything, i'm just curious as to what this noise is im hearing, i dont think its anything serious because the tranny shifts nice and smooth and has never slipped.
But anyway, can anyone else hear when your tranny is about to shift? I can actually hear when my tranny is about to shift, its not a loud noise, but i notice it when i drive like a grandpa the most because my truck is the quietest, i hear a high pitch squeal, and then it shifts. It does it every time it shifts into a higher gear.
Has anyone else ever heard anything like this before?
Thanks,
Tweav
Old Aug 19, 2011 | 11:20 PM
are you sure its coming from the trans? That just seems odd.....
Old Aug 19, 2011 | 11:23 PM
tweav88's Avatar
tweav88
Wow i just noticed the title, but yea, its weird, it makes the noise then shifts, thats the only time it makes the noise
Old Aug 19, 2011 | 11:24 PM
Mine doesn't do that....... Does it just sound like a short screech, as in something moving? Or, is it continuous, until it shifts?
Old Aug 19, 2011 | 11:26 PM
tweav88's Avatar
tweav88
Its just right before it shifts for a second or 2, then goes right away once it shifts, these tranny's shift electronically right?
Old Aug 19, 2011 | 11:33 PM
BackwoodsRam's Avatar
BackwoodsRam
yes it is
Old Aug 19, 2011 | 11:35 PM
tweav88's Avatar
tweav88
Originally Posted by BackwoodsRam
yes it is
So are there electronic motors actually doing the shifting? could that be what i hear
Old Aug 19, 2011 | 11:42 PM
BackwoodsRam
no there are no motors, soleniods and such in the valve body control the shifting and the dont make noise like that
Old Aug 19, 2011 | 11:57 PM
Only TCC, and O/D are solenoid controlled. The rest is all hydraulic. The governor on the 96 and newer trucks is also electronic, and that's why the get the designation RE instead of RH...... (RH trans has a mechanical governor)
Wonder if your trans mount is getting bad?
Old Aug 20, 2011 | 06:29 AM
Novarider's Avatar
Novarider
I would take it to a transmission shop. If something is wrong maybe they can fix it before it gets worse
