steering problems
Old Aug 24, 2011 | 12:57 AM
clemmert's Avatar
clemmert
Default steering problems
Ok I have a 1998 dodge ram 1500 with 11 inch lift and 38x14.5tires Toyota m/t tires and once I drive a little I loose power steering. I've replaced the pump twice and the gear box and still same thing. I was wondering if anyone knew what I could do to fix that
Old Aug 24, 2011 | 10:35 AM
What procedure are you using to bleed the air out of the pump?
Old Aug 25, 2011 | 05:35 PM
clemmert's Avatar
clemmert
I had a shop do it. Didn't wanna worry about messing it up
Old Aug 25, 2011 | 05:46 PM
Take it back to the shop. Show them the problem. Have them fix it. The only parts that have an affect on that are the pump, and the gear box. If it isn't working, one of those parts is bad......
Old Aug 25, 2011 | 06:00 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Don't know much about lift's. like I've stated in some other post's(and said I'd stay out of them) . But, 11"'s ? wow. If that lift is not installed correctly, you may be getting some binding going on.
BTW, you running that lift and those size tire's with stock 3:55 gear's?
