2001 Ram clutch issue
Have you downloaded the 2001 FSM from the FAQ section and looked through it? https://dodgeforum.com/forum/2nd-gen...e-manuals.html
I'm just trying to look at the color of my clutch fluid to see if it might be bad.
It looks like it's black for the top 3/4 of the reservoir and light brown at the bottom 1/4 (looking from the outside)
Can I just take the cap off, take a look at it, then screw it back on?
Or will that let in air/will I have to bleed it?
My clutch seems too easy to push down, but then again I've only driven one m/t vehicle so I can't compare. It shifts fine.... just trying to do some preventative maintenance.
Ok thanks. Just checked and realized the dipstick (or whatever is connected to the cap) was what made it look like it was black. The fluid level and color both checked out good. I'm guessing it must of been changed right before I bought it.
