Differential gear ration question ??
Old Aug 27, 2011 | 11:28 AM
gipperkid's Avatar
gipperkid
Default Differential gear ration question ??
I have been wanting 4.10 gears, currently have 3.55. I have a 4.10 front diff I can swap in my truck, but would still need to rear gear the rear diff. I know the whole thing about mismatched ratios, but would I be safe as long as I did not put the front drive shaft back in? This is just until I get the funds to rear gear in the back.
Old Aug 27, 2011 | 11:37 AM
So long as you don't engage four wheel drive, it will be fine.
Old Aug 27, 2011 | 11:39 AM
gipperkid's Avatar
gipperkid
That's what I thought, I just wanted outside input. Thanks.
Old Aug 27, 2011 | 11:56 AM
lastrights's Avatar
lastrights
why do the front first ? if anything do the rear first , because u cant engage in 4wd anyways at least in the rear you can just drive with it. just dont engage .
Old Aug 27, 2011 | 02:06 PM
Probably because the whole axle, with the right gears, is cheaper than gears, and installation.
Old Aug 27, 2011 | 02:28 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by lastrights
why do the front first ? .
Because he obviously found one for the front first.
