NP231 J transfercase on my RAM?
Old Aug 28, 2011 | 02:28 PM
Stoft's Avatar
Stoft
Default NP231 J transfercase on my RAM?
Hello
Can I use a NP231J (Jeep) transfercase on my dodge?
I have a NP231 now.
Old Aug 28, 2011 | 02:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Any chance you could tell us at least what year your truck is. And what year the 231 from the Jeep is? Add ALL the info about your truck to your sig. Anyway. I don't think it will work regardless. The shift patterns are different.
Old Aug 28, 2011 | 04:17 PM
BackwoodsRam's Avatar
BackwoodsRam
no it woudnt, no matter what model you use. the casings for all np231 are the same but the internals in a j model are about half the size of the internal on a d or hd model. i actually used a j model case when i built my t-case but i used internals from a d and an hd but the only thing from the jmodel were the front and rear case halfs
Old Aug 29, 2011 | 10:34 AM
Stoft's Avatar
Stoft
Okey! Thanks
Old Aug 29, 2011 | 05:35 PM
Stoft's Avatar
Stoft
When I drive my shifter rattles a lot. Can it be adjusted?
Sometimes when driving in 4H and 4L it feels like it jumps out of gear and then i get the metall sound..
Maybe i can adjust it?
Dodge Ram 1500 5.2l Magnum 1997
Old Aug 29, 2011 | 05:42 PM
zman17's Avatar
zman17
Have you tried looking at this? Could be the front axle not engaging. http://www.dodgeram.org/tech/repair/..._engagment.htm
Old Aug 29, 2011 | 05:43 PM
Check the snap ring on the rear output shaft, make sure it is still there. (gotta pull the rear driveshaft, and tailshaft housing.)
There are various bushings and such in the shift linkage, have a look, see if any of them are sloppy. Also check motor/trans mounts.
Old Aug 30, 2011 | 04:28 AM
Stoft's Avatar
Stoft
Thanks.
The 4wd works great but sometimes it´s like two gears touching eachother and makes a terrific noice (Or jumping out of gear, gets panic all the time when it happens so i brakes and turns off the engine)
The snap ring is still there. (I have changed all the gaskets)
Old Aug 30, 2011 | 07:48 AM
zman17's Avatar
zman17
Could be the TC, but sounds to me like a vacuum problem.
