96 Dodge Ram 1500 5.2l 8cyl won't turn start
Old 08-30-2011 | 07:54 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Old 09-01-2011 | 04:07 PM
ronkirby09's Avatar
ronkirby09
Replaced the Distributor cap and rotor and nothing has changed. It tries to turn over but it wont. It makes a clicking sound after trying to start it. The truck was hooked to jumper cables. Did I mess up on replacing the distributor and rotor?
Old 09-01-2011 | 04:14 PM
zman17's Avatar
zman17
it will click if the battery is dead or bad. But, did you bother to read the the link I posted?
Old 09-01-2011 | 04:27 PM
ronkirby09's Avatar
ronkirby09
Yes I did. I checked and there is a lot of smudge down there so it looks like I will be replacing the Plenum gasket.
Guess I will be getting a new battery it looks like.
Old 09-01-2011 | 04:31 PM
zman17's Avatar
zman17
Try unscrewing the pre cat o2 sensor, see if it runs any better.
Old 09-01-2011 | 04:53 PM
zman17's Avatar
zman17
Unsrew it BEFORE you try and start it.
Old 09-01-2011 | 05:01 PM
ronkirby09's Avatar
ronkirby09
I will try that once I get it started, if I do lol
Old 09-01-2011 | 10:26 PM
ryan0714's Avatar
ryan0714
ok after reading all this, not to say anyone is wrong.... but, the clicking you hear is the starter seloniod which is ran off battery power, so your battery is good. im sure you know how to test for spark at your plugs, but to me it sounds like a fuel problem. try to bang on the bottom of the tank and see if you can get the thing to start, if you can then its gonna be your fuel pump. or you can goto autozone and borrow a fuel pressure tester and hook it up to your fuel rail and turn the truck over and see what it reads.
Old 09-23-2011 | 12:37 AM
ronkirby09's Avatar
ronkirby09
Just dropping by to give an update. The fuel pump was the culprit and discovered #8 cylinders was misfiring due to a bad injector. I got a new battery also since it was in there since 2006.
Old 01-14-2012 | 05:23 PM
tooclose1's Avatar
tooclose1
Default 95 ram 1500 5.9 stalled wont start?
i have a 1995 dodge ram 1500 5.9 and it stalled last night and wont start. if i let it sit for a few minutes and try to start it, it will run rough for about 5 seconds then stall again.i checked the fuel rail and i get plenty of fuel,i dont know what it could be??? any suggestions?Thanks ! Steve.
Quick Reply: 96 Dodge Ram 1500 5.2l 8cyl won't turn start
