Lucas Additives
Old Aug 29, 2011 | 01:47 PM
  #21
zman17's Avatar
zman17
Retired Moderator - RIP
Yep, add it every time you do your regular interval oil changes.
Old Aug 29, 2011 | 03:10 PM
  #22
EFS463's Avatar
EFS463
Well, I thought my truck was still burning oil. 500 miles in, its still a little hard to tell. But when I got up this am to go to work, I popped the hood and checked the oil....was at the same level it was when i changed it. About 2 hours after I got home, I checked again, 50 more miles, and it still hasnt moved. Maybe Engine Restore did its job, because my truck has been running slightly better with improved oil pressure, and its not burning any oil yet.
Old Aug 29, 2011 | 03:27 PM
  #23
zman17's Avatar
zman17
Good luck with that stuff. It will only be temporary.
Old Aug 29, 2011 | 09:44 PM
  #24
pavement_hater's Avatar
pavement_hater
I can honestly say the fuel additive works wonders. Saw great results from it when my mom added it to her 88 Aries. I have used the oil stabilizer but not sure it made any difference. I will say when I worked in the shop at the truck stop that truckers love the stuff and some swear by it.
Old Aug 29, 2011 | 10:58 PM
  #25
aim4squirrels's Avatar
aim4squirrels
I team engine restore a few years ago and noticed a significant bump in compression and engine performance.
Then I pulled the iengine apart to replace the heads. I found coke in the various nooks and crannies of my engine. Not just sludge, but actual coke. Dried, burnt crust, soaked on outside in oil.
Old Aug 29, 2011 | 11:49 PM
  #26
EFS463's Avatar
EFS463
If I only used it for one oil change (and I change every 3000) should I be ok? I dont plan on using it again.
Old Aug 31, 2011 | 09:36 PM
  #27
MonteC's Avatar
MonteC
Originally Posted by heyyou
I always swore AT the engine restore. Rebuilding a motor after the owner had been using that stuff was a drag. It's supposed to 'build up surfaces'.... well. it does. With oil sludge, and other crap. I don't like it, won't use it, and hate it when I have to work on a motor that had it in it. I thank my lucky stars I don't do that for a living any more.
Now imagine what it does to the transmission!
Also, there is only ONE additive I do recommend. A product called SMART BLEND, by Life Automotive. Its good stuff.
