how to diagnose a/c compressor clutch
Old Aug 30, 2011 | 07:39 AM
Novarider's Avatar
Novarider
Originally Posted by chadhager03
It's 5 ohms and mine turned out to be the coil like heyyou said. I had the same symptoms as you, and not to threadjack but I'm 99.99% sure that's the problem, my heat doesn't work because my a/c clutch still runs when I turn that little *** all the way to the red and the a/c clutch stays engaged, any quick fixes for this? My heater core doesn't seem to come on either. But the heat does work a little.
You can run the a/c with the heat and it will still be hot
