98 ram 1500 5.9l magnum bogging out and idles low
Old Aug 30, 2011 | 03:56 AM
AJenkins's Avatar
AJenkins
Default 98 ram 1500 5.9l magnum bogging out and idles low
Hi guys wondering if you could helpe out with a problem I had a check engine light come up then my truck started to idle real low at stop lights and start to bog out then I'd have to floor it to get it back up and running they code was for a o2 sensor so I changed them and the problem still persists.
I had a new magnaflow cat put it on 3 months ago
Wondering what else could cause this problem.
Old Aug 30, 2011 | 03:58 AM
AJenkins's Avatar
AJenkins
And all the ignition wires and plugs are new
Old Aug 30, 2011 | 07:49 AM
zman17's Avatar
zman17
Retired Moderator - RIP
remove the TB and clean it and the IAC on back. While the TB is off check around inside the intake for oil.
Old Aug 30, 2011 | 09:12 AM
and don't forget to have the battery disconnect while you are cleaning things.
Old Aug 31, 2011 | 06:56 PM
AJenkins's Avatar
AJenkins
Thanks guys that cleared it all up
