Rock Solid Ram Steering Fix, How good is it?
Old Aug 30, 2011 | 07:08 PM
talthyren's Avatar
talthyren
Default Rock Solid Ram Steering Fix, How good is it?
Came across this on the forums here...: http://www.rocksolidramtrucksteering.com/
Has anyone ever had any luck with this? or can vouch for it doing what it says it does?
I have the clunking in my steering column and lots of play.... for $60 if it does what it says it does it would be an incredible value...
Whats involved in installing it? Is it easy to install for someone like me? Im not the best DIY'er ...I change my own oil and fluids and do my own tuneups....that's the scale of my expertise..lol.
Thanks guys.
Old Aug 30, 2011 | 07:13 PM
aim4squirrels's Avatar
aim4squirrels
You'll need to read the instructions to know if you are comfortable doing it. I believe there is a thread about an install around here, might even be in the DIY section.
A for whether or not out will fix your problem 100%, it depends on if the that worn bushing is truly your problem. It will tighten up the steering.
Old Aug 30, 2011 | 07:29 PM
talthyren's Avatar
talthyren
A for whether or not out will fix your problem 100%, it depends on if the aghast and that worn nursing is truly your problem. It will tighten up the steering.
For $60 id be willing to risk it either way, My biggest concern is not being able to install it myself...Ill look around for a link to the instructions..
Old Aug 30, 2011 | 08:33 PM
aim4squirrels
Wow that was a terrible post. this phone auto spelling correction is pretty bad, LOL.
Old Aug 30, 2011 | 09:01 PM
gdstock's Avatar
gdstock
I've added this to my project list, and ordered it today. Instructions make it seem pretty simple, or as simple as it could be in tight quarters. (wonder if they have a warehouse in Denver! lol)
I think I saw a You Tube video on this also.
Old Aug 31, 2011 | 07:32 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The left to right play is the gear box or some other steering component. Need to have a friend saw the wheel back and forth while you look at everything starting at the bottom of the steering column. The rock solid bushing will fix the clunk.
Old Aug 31, 2011 | 09:41 AM
talthyren's Avatar
talthyren
Does anyone happen to have the instructions handy? Or could link to a post that has them somewhere? I cant find anything in the DIY section.
Old Aug 31, 2011 | 09:44 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Why not contact the people at Rock Solid and ask if the kit comes with instructions? Damn, do you want someone here to wipe your butt as well?
Old Aug 31, 2011 | 09:47 AM
zman17's Avatar
zman17
There is no DIY, the kit comes with directions(as said on the website)and is rather easy.
Old Aug 31, 2011 | 12:12 PM
gdstock's Avatar
gdstock
Default Steering
My luck holds true to form. I have the clunk, excessive play, AND leaky gearbox. Shucks, the pump leaks as well. What is one more than a trivecta or hat trick? Afraid to look at ball joins and such - but I will eventually. 160000 and so much to do. Truck was neglected for years.
