Rock Solid Ram Steering Fix, How good is it?
Old 08-31-2011 | 12:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yep, you sure do have a lot of things to check and replace.
Old 08-31-2011 | 12:32 PM
heatonsV10's Avatar
heatonsV10
Let me know how it turns out. I need to tighten the steering a bit to. But I need new tires and an alignment first. But keep us updated.
Old 08-31-2011 | 12:36 PM
zman17's Avatar
zman17
Old 08-31-2011 | 03:42 PM
TheycallmeLaramie's Avatar
TheycallmeLaramie
I ordered this and have it waiting to be installed at my place. Its a bushing and a piece of pvc to help push the bushing up. You basically disconnect the knuckle underneath the brake booster. use a dremel to cut the spring retainer out, pull the old bushing out, install the new bushing, turning your steering back and forth if you need it more snug push the bushing in more. Once you got it right put the retaining clip in and put back together. Old hard thing is the confined space. I have the instructions and can scan em and post em tomorrow if you really need it.
My steering is fine now at 205,000k so im just waiting for it to slop a bit before i mess with the steering.
Old 08-31-2011 | 04:26 PM
talthyren's Avatar
talthyren
Thank you very much, could you please scan em and post em?
Old 08-31-2011 | 04:28 PM
zman17's Avatar
zman17
+1..... That would be very helpful for people deciding whether or not they can do it themselves.
Old 08-31-2011 | 05:13 PM
TheycallmeLaramie
Ill do it tomorrow just check back.
Old 08-31-2011 | 05:15 PM
zman17's Avatar
zman17
I have them too, but I'll be damned if I can find them.
Old 08-31-2011 | 05:21 PM
heatonsV10's Avatar
heatonsV10
Originally Posted by zman17
Thanks. Thats good stuff.
Old 08-31-2011 | 06:45 PM
gdstock's Avatar
gdstock
Great instructions from Genos. Already ahve it on clip board on bench. I am also going to check gear backlash (wish I could find mfg specs) to see if it has excessive or uneven wear. May be able to determine approriate backlash in Machinist's Handbook. If I can, I would prefer to rebuild than buy new one. They are pretty expensive, and a used one may not be much better than what I have.
Quick Reply: Rock Solid Ram Steering Fix, How good is it?
