Oh thank God, a Ram forum not full of idiots.
The brakes are solid. New lines and brake booster/master cylinder not too long ago.
The sucking noise mostly occurs when the truck is first started and takes off down the road. It only started doing it after the PO replaced the plenum gasket.
I don't want to replace the rear sensor because I'm told it's been done before by the PO without fixing the problem. I'm going to check voltage with my meter when I get some time, if I can get under there and figure out how...
hell of a nice truck for $1800
as said probably dana 60's. you can email dodge and get a build sheet for free. it'll tell you all the options/equipment that it came with. do a search on 'build sheet' for the email.
in addition to in/around the throttle body, consider that the intake gasket might be leaking, especially at the back of the block where the rubber gasket can slide out during reinstall and not be seen. if it is that, a cheap fix is a big smear of rtv along the seam. one last easy fix is the air filter. its surprisingly hard as hell to install and tighten. and as zman said - there is supposed to be a rubber gasket under the air cleaner and it always gets lost. its only $1-2 at any parts store.
no speedo is likely either top of rear diff -rear abs sensor, or tail housing of transmission speed sensor. either is fairly cheap.
adjust steering box to remove excessive play.
is it 4wd - replace track bar with moog from rockauto for about $105
ha, give us a little more time and we'll all be idiots.
I'd say $1800 for a decent looking, 4x4, 3/4 ton is a good buy!
Have someone shimmy the steering wheel back and forth maybe 1/8 of a turn and take a look at all of the steering components to pinpoint the slack. The loose joints should be obvious. Don't forget the track bar (as dhvaughan mentioned).
Check your airbox for cracks. Some guys can't read, so the sticker on the front of the airbox goes unnoticed and they try to pry the airbox apart while it's still on the throttle body....
Sorting out the small things is gonna be the pain, but it should be worth it in the end.
i just put all new moog front end parts on my 01 2500 and it cost me almost 500$ for everything, i put it on myself and did a halfass alignment to get me to belle tire, but if i could do it all over again and id go this route
http://thurenfabrication.com/crossover.html
For as many miles as it has, it's a very quiet and smooth riding truck. I drive it back and forth to work daily and it's a nice ride. The speedo is driving me crazy, because I've been wanting to figure up my MPGs, and I can't do that reliably without an operating ODO.
I need to get some cash together for a work day, as both front and rear diffs need serviced, along with the Xfer case.
I've gotten a build sheet from my Chrysler dealer before for a Grand Cherokee I had. If I have time I'll run out there today, but I might just try the online one.
The online build sheet will take 2 to 4 days (I think mine took 3) to get a reply.
Other than being white..nice find. Daily driver? either a short commute or just plain crazy.
I'd much rather have the factory equipment up and and working. A bit silly this is so problematic, but it is a Dodge after all.
I'm just hesitant to start replacing different sensors only to have that not solve the problem.
