P 1494 code?
Old Sep 1, 2011 | 12:49 AM
jesssed's Avatar
jesssed
Default P 1494 code?
I looked up the code on the FAQ sheet "leaking pump switch or mechanical". what does this mean?
thank you
Jesse D.
Old Sep 1, 2011 | 01:13 AM
dhvaughan's Avatar
dhvaughan
P1494 is a vac leak in/around the evap system. on my 01 its on the passenger side fenderwell, right behind the headlight. check all those vac lines for cracked ends. disconnect each one and look for swelling or cracks. for a quick fix you can likely cut off an inch or so of any that are cracked.
turn of cel by disconnecting negative batt cable and turning on headlights for 30 sec. if its still leaking, cel will come back on in about 3 days.
one of 1000's of google hits.
http://www.fixya.com/cars/t2438036-r..._dodge_caravan
