Heater Core, Too much of a PITA to DIY? or worth it?
Old Sep 1, 2011 | 01:14 PM
talthyren's Avatar
talthyren
Default Heater Core, Too much of a PITA to DIY? or worth it?
I bought a new core for $75 at Part Source (Dealership wanted $250 for the same thing WTF!!!)
My friend who is a decent mechanic is going to help me change it out, I know generally what needs to be done...
- Drain coolant
- Remove dash
- Remove/replace core
- Put everything back togeather.
- Refill coolant
He mentioned we might have to drain the AC also? Anyone know if/why that would be necessary? As far as I know the heater core has nothing to do with the AC system.
Ive had 2 Mechanics quote me $650 and $700 to do this entire job from start to finish...way to expencive for me....Both told me the AC would need to be drained and re-charged, which is a contributing factor to the cost...
So is it worth my time to try to DIY this and potentially save $500?
Old Sep 1, 2011 | 01:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
If money is an issue, return the heater core you bought and get one as described in this thread. The search button is working again, LOL.
https://dodgeforum.com/forum/2nd-gen...tructions.html
Old Sep 1, 2011 | 01:32 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
- Drain coolant
- Remove dash
- Put everything back together.
- Refill coolant
Ive had 2 Mechanics quote me $650 and $700 to do this entire job from start to finish...way to expensive for me....Both told me the AC would need to be drained and re-charged, which is a contributing factor to the cost...
No. You're better off selling the truck since you can't even bother to read through the FAQ/DIY sticky on this forum.
Old Sep 1, 2011 | 04:15 PM
PurplDodge's Avatar
PurplDodge
Dont buy the cheap *** heater core. The $200 dealer one is worth it.
This is a steal:
http://cgi.ebay.com/ebaymotors/Dodge...item23130b648b
Old Sep 1, 2011 | 04:23 PM
zman17's Avatar
zman17
This is a steal:
Not if money and labor is an issue, like the OP stated.
Old Sep 1, 2011 | 10:31 PM
talthyren's Avatar
talthyren
It is a huge issue...But I also don't want to put something in the truck that's going to break in a month....The $75 one I bought doesn't look low quality or anything..Its sturdy, and has the hoses you can move which should make it easier to install.
If I get 1-2 more years out of this truck Ill be happy...basically that's my attitude right now....Will the $75 one be fine?
Old Sep 1, 2011 | 11:02 PM
CappinHoff's Avatar
CappinHoff
I know you already bought it but you should check what the dealer has. I know around here the dealer uses the same HC as autozone sells. Which AZ sells for $75.
Old Sep 1, 2011 | 11:34 PM
dhvaughan's Avatar
dhvaughan
the AC evap core is in the same air exchange box as the heater core. no personal experience but in some of the past threads there was just barely room to replace the heater core without disconnecting/recharging the AC.
if money is not too tight, some people go ahead and replace the AC evap, just because its so much labor to pull the dash. its not an expensive part.
Old Sep 2, 2011 | 12:14 AM
talthyren's Avatar
talthyren
I did check just now actually, it looks like EXACTLY the same thing...same color, same material..just has a Chrystler logo on it... $259.99 ....Whereas my Auto-Zone one was $75 and doesn't have the logo....
talthyren's Avatar
talthyren
Thanks for the tip, I will see how much an evap core costs.
