Transmission oil pan leaking
Old Sep 3, 2011 | 07:22 PM
Stoft's Avatar
Stoft
Default Transmission oil pan leaking
Hi..
Got a small tiny hole in my transmission oil pan.
Can I weld it or must i buy a new one?
Dodge RAM 1500 5.2 1997 4x4
Old Sep 3, 2011 | 08:05 PM
BIGBIRD85's Avatar
BIGBIRD85
tiny hole can be welded. but i would get a new one. just my opinion
Old Sep 3, 2011 | 08:44 PM
Cloak's Avatar
Cloak
u can use JB Weld too....just a temp fix, but it will work
Old Sep 4, 2011 | 04:12 PM
Ram15002ndGen's Avatar
Ram15002ndGen
That is the perfect spot to put a drain plug in. Knock out two birds with one stone.
Old Sep 4, 2011 | 04:26 PM
gdstock's Avatar
gdstock
x2 for the draing plug!
Old Sep 4, 2011 | 06:31 PM
stewie01's Avatar
stewie01
I'm a little surprised zman17 didn't chime in with the drain plug idea already
Old Sep 4, 2011 | 06:53 PM
dhvaughan's Avatar
dhvaughan
on the drain plug, you'll have to mount it in one of the flat panels that are stamped into the bottom of the pan. also watch out for clearance of the solenoids in the rear. if you can line up the drain plug and avoid these problems, that great, go for it.
otherwise, you can weld up a hole if you have enough metal to work with. but - its pretty thin, so if its rusted out, you may not have anything left to weld, and JB Weld might be a better choice. that stuff is amazing and i've used it to fix gas tanks, mufflers, porcelain toilets, ...etc.
Old Sep 4, 2011 | 10:50 PM
plott hound's Avatar
plott hound
when my pan started to leak i thought about patching it.when i probed it with my finger i poked a hole right through it.damn thing was totally NFG.
Old Sep 4, 2011 | 11:12 PM
aim4squirrels's Avatar
aim4squirrels
Blowing out your toilet on a midnight bombing run and devising a MacGyver type fix with items you had in the garage is a bit more than I'd share with the forum, but if you're fine with it, who am I to judge? I assume incorporating the muffler and "gas tank" into this toilet contraption were for the family's benefit.
Old Sep 4, 2011 | 11:23 PM
gdstock's Avatar
gdstock
Default Funny
Now that's funny...I don't care who you are!
