My first time doing ball joints today....
Old Sep 5, 2011 | 06:19 PM
96magnumram's Avatar
96magnumram
Originally Posted by stewie01
I've not payed much attention to the bottom ball joints but the top ball joints on my 01 are bolt on.
Gotta grind off the rivets though.
Yeah, all mine press in...the first side was a PITA, but after we figured out what the heck we were doing, the other side was cake!
Old Sep 5, 2011 | 07:00 PM
chadhager03's Avatar
chadhager03
After all of it was finished (if you are) how long did it take you?
Old Sep 5, 2011 | 07:06 PM
96magnumram
Well, yesterday it took us about 3 hours on the first lower ball joint, just figuring out how in the heck to use the press...we ended up having to take a flat piece if steel to use with the press...
After we figured everything out, today we done the upper on the drivers side and both upper and lower on the passenger side in about an hour and a half...not a hard job at all once you figure out what in the heck you're doing!!!
Old Sep 5, 2011 | 07:14 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Even though I missed the 2wd part originally, I do know that most likely the procedure is different for a 96, than it is for a 2001.
Old Sep 5, 2011 | 07:31 PM
stewie01's Avatar
stewie01
I wouldn't think it'd be too different. How much did the front end change from 96 to 01 on a 2WD setup?
I wouldn't think it was that dramatic of a change. But there's a fairly good chance I could be wrong too.
I do know that the brake setup on the 01's has dual piston's
Old Sep 5, 2011 | 07:34 PM
chadhager03
Well I have a 4wd so I know that's going to be more fun. I was just curious because I want to do this soon, well after the Plenum, transmission rebuild, sct tuner, and I want to try to paint it but I need to squeeze this in somewhere because it feels like I'm running over a curb when I hit speed bumps.
Old Sep 5, 2011 | 07:43 PM
zman17's Avatar
zman17
Because depending on year, some are pressed, some riveted, some bolted, and not to mention the PO might have had them tack welded. And your right, that isn't a dramatic difference, but also the wheel bearing style was changed.
Old Sep 5, 2011 | 07:46 PM
stewie01's Avatar
stewie01
Well now I know
Old Sep 6, 2011 | 08:52 AM
Wow, you are a LOT younger than I thought.......
Old Sep 6, 2011 | 10:56 AM
stewie01's Avatar
stewie01
Yeah I'm only 25. But this is my first experience with Dodge Trucks, or Dodge anything for that matter.
