Fuel sync problems and P1391
Old Sep 6, 2011 | 10:13 AM
molar? You put a tooth in there?? If you have a mopar crank sensor...... then you have either a wiring problem, (which aren't always easy to find...) or, your pcm is freaking out.
Old Sep 6, 2011 | 12:06 PM
dodgeboy7's Avatar
dodgeboy7
I have two pcm both doing same thing and the spelling is my phone try to fix it lol
Old Sep 6, 2011 | 12:25 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Is the Molar crank sensor new?
Old Sep 6, 2011 | 02:00 PM
aim4squirrels's Avatar
aim4squirrels
A bad coolant temp sensor can cause knocking where you can't figure out what is causing it.
I don't mean to say its your specific problem, but it is a major cause of unexplained knock.
A bad cam or crank sensor usually just a shuts the truck down.
Old Sep 6, 2011 | 02:19 PM
dodgeboy7's Avatar
dodgeboy7
Now that u say that I did replace it with a cheap one I check them when I get home is there a way to test them I have two
Old Sep 6, 2011 | 02:23 PM
dodgeboy7's Avatar
dodgeboy7
Yes it was new
Old Sep 6, 2011 | 02:29 PM
If you have a scanner, see what temp your engine things it is, and compare that to the in-dash gauge, and what you think it SHOULD be. (one of your sensors is for the PCM to read engine temp, the other, which also goes thru the PCM....... is for the PCM to drive the gauge in the dash.)
Most parts stores have scanners that should be able to read the data.
Old Sep 6, 2011 | 02:47 PM
zman17's Avatar
zman17
I see no mention about the cat.
Old Sep 6, 2011 | 04:33 PM
dodgeboy7's Avatar
dodgeboy7
Ok I check that with my snap on mt2500 and the cat it fine and would not cause it to knock and carrie on like that I had one go bad already
Old Sep 6, 2011 | 04:35 PM
zman17's Avatar
zman17
I dont have a mt2500, how do you check the cat with it?
