Fuel sync problems and P1391
Old Sep 6, 2011 | 05:11 PM
  #21
dodgeboy7's Avatar
dodgeboy7
Originally Posted by zman17
I dont have a mt2500, how do you check the cat with it?
No I am checking the coolant temp with it the cats fine
Old Sep 6, 2011 | 05:16 PM
  #22
zman17's Avatar
zman17
Retired Moderator - RIP
Ok then, that's what I'm asking. How do you know it's fine? (the cat)
Old Sep 6, 2011 | 05:21 PM
  #23
dodgeboy7's Avatar
dodgeboy7
b/c i drop the y pipe plus it not acting like it is bad or making the funny noise that it dose when they do go bad
Old Sep 6, 2011 | 05:36 PM
  #24
zman17's Avatar
zman17
There is no set noise they make when they are bad. So you dropped the Y and took it for a ride?
Old Sep 6, 2011 | 06:12 PM
  #25
dodgeboy7's Avatar
dodgeboy7
Yes it dose the same thing just really loud lol
Old Sep 6, 2011 | 06:40 PM
  #26
dodgeboy7's Avatar
dodgeboy7
So this is what i just did to test the coolant temp sensors, i hooked up the snap on scanner and watched the live data screen and watched my temp go from 72 to 189 and i watched my gauge on the dash. I dont think it could be any more dead on. Some thing i did notice though it idle fine till it got to 180 ~185 about and the loopy idle started and i kept checking the fuel snyc while it was warming up and notice it was at 0 to 3 the whole time till the loopy idle started then went to 14~15. It also cant stay running more then 30 sec or so b/c of the idle.
Old Sep 6, 2011 | 08:07 PM
  #27
dodgeboy7's Avatar
dodgeboy7
Look at what i found MMMMMM makes me want go run outside
http://www.ramforumz.com/showthread.php?t=37781
Old Sep 6, 2011 | 11:01 PM
  #28
How old are your O2 sensors??
Old Sep 7, 2011 | 02:24 PM
  #29
dodgeboy7's Avatar
dodgeboy7
Not that old maybe a year
Old Sep 7, 2011 | 02:34 PM
  #30
zman17's Avatar
zman17
If you are referring to that link as far as the vacuum leak. I could have sworn you mentioned that you checked everything. Too many threads, too much reading to remember. I too would check all the vac components and lines, etc.... If for nothing else, than to eliminate it. Just like the clogged cat.
