Fuel sync problems and P1391
Old Sep 8, 2011 | 05:49 AM
  #31
dodgeboy7's Avatar
dodgeboy7
Originally Posted by zman17
If you are referring to that link as far as the vacuum leak. I could have sworn you mentioned that you checked everything. Too many threads, too much reading to remember. I too would check all the vac components and lines, etc.... If for nothing else, than to eliminate it. Just like the clogged cat.
I did check for vacuum leaks But I was not sure if I pulled the line for the pvc valve
