High RPM (1500-2k) after IAC problem
Old Sep 9, 2011 | 01:56 PM
  #21
Step on the pedal, and see what that number does. It should go up smoothly, to greater than 75..... if it does anything other than that, replace the TPS.
Old Sep 9, 2011 | 02:07 PM
  #22
zman17's Avatar
zman17
Retired Moderator - RIP
The reason I asked him about the % thing, is because my Genisys starts out at 11% and goes to 70% at WOT. But it is not as smooth in between as testing the volts with a meter. As you have described many times.
Old Sep 9, 2011 | 03:15 PM
  #23
Good point. Sometimes, the older technology is better for the job....
Old Sep 9, 2011 | 03:40 PM
  #24
kurts2's Avatar
kurts2
It that 14.1 % ?
I found a service guide for the scaner and yes its %
Old Sep 9, 2011 | 04:35 PM
  #25
zman17's Avatar
zman17
Like has been said, get the Haynes out, and check it with a multimeter.
Old Sep 10, 2011 | 10:58 AM
  #26
kurts2's Avatar
kurts2
I only have the Chrysler shop manual and im not sure if its the same, but it checked good. However, the low side is where I am concerned and according to my text, its good if greater than 200 mv! You would think there would be a maximum high value fir the low side, unless the PM just recalibrates rvrry time with whatever value you start at.
Old Sep 10, 2011 | 11:05 AM
  #27
zman17's Avatar
zman17
The Haynes says 0.5 to 1.5 volts.
Old Sep 10, 2011 | 05:25 PM
  #28
kurts2's Avatar
kurts2
Thanks for that. Wow better info in Haynes on this! I assume that's the low end accepted range. What does it say about the upper?
Old Sep 10, 2011 | 07:10 PM
  #29
zman17's Avatar
zman17
I don't know, buy one and look. LOL 3.5 to 4.5 volts
