rear end flip
Old Sep 9, 2011 | 05:15 AM
milesdude1's Avatar
milesdude1
I'd rather have the rear lower than the front. You shouldn't need notches if you have that much clearance, just drive slow and you'll be good.
Old Sep 9, 2011 | 09:31 AM
Why? Not a good idea for both aerodynamic, and suspension geometry reasons.
Old Sep 9, 2011 | 11:18 AM
97tn4x4's Avatar
97tn4x4
On a lowered truck I agree, back lower than the front. Just looks cleaner.
Old Sep 9, 2011 | 01:16 PM
chrisdodge96ram5.2's Avatar
chrisdodge96ram5.2
How bad does it feel in the cab? Haha
Old Sep 9, 2011 | 01:17 PM
chrisdodge96ram5.2
Hmm how much lower are u thinking ? 2"s the Max difference?
Old Sep 9, 2011 | 01:22 PM
a-master's Avatar
a-master
hehe lowered... sorry,i had to say it.
Old Sep 9, 2011 | 01:50 PM
Terribly sorry, but, wholeheartedly disagree. The rear of these trucks are already significantly lighter than the front, having the rear lower, is going to turn the truck into a wing, trying to lift the rear some more. At freeway speeds, it will be unstable. In any sort of inclement weather, it will be even more unsafe to drive.
Not to mention the horrid things it is going to do to your steering geometry. Caster is going to be WAY out of whack. Caster being the setting that makes your truck want to travel a straight line......
Very Bad Plan. Even should you have the alignment set within spec for the rear being lower, you are still going to see all the other issues mentioned. If this was a low-speed, parade only vehicle, that would be 'ok', but, for a DD, I would never even consider it.
Old Sep 9, 2011 | 02:13 PM
chrisdodge96ram5.2
Ok! Thanks! Good advice. Ive been looking around and the flip kit would make the back to low, so thinking of taking out 1 leaf spring to bring it down a little. Yay or nay?
Old Sep 9, 2011 | 03:07 PM
redneckrocket38's Avatar
redneckrocket38
Slam that b!tc#. I love a lowered 2nd gen. You can get away with a 4/6 without notches, Although notched would be better. Im gonna do a 2/5 when the funds permit. Post up some pics when you get er done.
