Strange symptom- Four-wheel drive lever moving under load
Old Sep 8, 2011 | 09:01 AM
kadetklapp's Avatar
kadetklapp
Default Strange symptom- Four-wheel drive lever moving under load
I noticed this the other day, and IDK if I should be concerned or not, but as I was backing out of my driveway I noticed as I gave the truck some gas, the four-wheel drive lever moved as if the transfer case was under load or engaged, even though it was not. I drove slowly down the street and gave it some gas and watched it move again. I'm just concerned something is not disengaging along the four-wheel drive system and will cause a problem. I also noticed I've got ATF leaking from the rear output seal of the transfer case. Are these things indicative of a major issue?
Old Sep 8, 2011 | 09:03 AM
Shifter moving side to side as engine load changes? Fairly normal for some movement, as it is mounted to the trans/t-case. If the movement seems excessive, check the engine and trans mounts. If they are worn/broken/loose, they can allow excess movement.
Old Sep 8, 2011 | 09:04 AM
zman17's Avatar
zman17
Retired Moderator - RIP
lever moving is normal. The leak can be fixed with a new seal. Check the ujoints while the shaft is out.
Old Sep 8, 2011 | 12:13 PM
kadetklapp's Avatar
kadetklapp
The lever moves forwards and backwards. Not sure if it matters.
I've got a pretty loud metallic clunk from the shaft when going between Drive and Reverse so I bet I need U-joints anyway.
Old Sep 8, 2011 | 12:43 PM
Check the rear mount. I may have separated.
Old Sep 8, 2011 | 12:49 PM
zman17's Avatar
zman17
How much does it move? They all do it to some extent. And if you hear a clanking, I'd would check the ujoints, that could explain why the seal is leaking.
Old Sep 9, 2011 | 10:13 AM
kadetklapp's Avatar
kadetklapp
Rear mount of what? Transfer case?
Old Sep 9, 2011 | 10:29 AM
zman17's Avatar
zman17
Yea Tranny or TC. Theres only one back there.
