Carbon fouling, Idle rough, running RICH at idle
Old Oct 5, 2011 | 12:35 PM
  #21
Forceofwon's Avatar
Forceofwon
Originally Posted by ttrash91
just a thought as im reading this.....wouldnt a vaccumm leak cause a lean burn, NOT rich..
just sayin
glad ya gotter goin!
I blame the carbon fouling/rich mixture on the EGR valve. When I bought the truck it was disconnected, and plugs were fine. I put a new EGR valve in it and it started fouling plugs. I also remembered I had the same problem with a 71 Charger with a 318 I had once. It had a EGR valve mounted on the manifold. I blocked it off and it stopped fouling plugs too.
Old Nov 11, 2022 | 08:25 PM
  #22
Wasgas's Avatar
Wasgas
Default Thank you!!!
Originally Posted by Big Lar
I had problems similar to this and the guys here suggested the Engine Coolant Temp Sensor,
Larry
I just replaced the lifters on my wife's car and it wouldn't run right and would barely start fule smoke everywhere and all plugs fouled. After reading this I realized the issue. I had the water pump out as it was leaking and I was waiting on the replacement the COOLANT TEMP SENSOR was still unplugged. You saved me a ton of work and money thanks 🙏
