OBD port fuse location?
Old May 2, 2014 | 02:51 PM
Cojmpr's Avatar
Cojmpr
Default OBD port fuse location?
Looking for the fuse to my OBD port. Any help locating this would be appreciated!
1996 1500 4x4 5.2
Thank you!
Old May 2, 2014 | 03:38 PM
Fuse 20 in the block on the side of the dash. Glove box light, brakes lights, and some other stuff are on that as well. Should see 12 volts at pin 16 in the DLC.
Old Nov 11, 2022 | 03:48 PM
usmc123456789's Avatar
usmc123456789
Unfortunately the OBD port is dead. I may try putting the old one back in and see if the light goes off, I went for a drive and the shifting issue is still there so I don't think replacing the throttle position sensor fixed it anyway...
Old Nov 11, 2022 | 06:23 PM
If the sensor is bad, no, it won't fix it.
How much of an RPM drop are you seeing?
Old Nov 11, 2022 | 08:00 PM
usmc123456789
Not much, only 200 RPM or so. It definitely feels like it's changing gears but when I turn off the overdrive the problem goes away.
Old Nov 11, 2022 | 08:43 PM
That's torque converter clutch engaging/disengaging. 90% of the time, that is indeed the TPS.
Old Nov 11, 2022 | 09:04 PM
usmc123456789
Thanks, also a fuse was popped out for the OBD so I got it going, I got 2 codes - PO122 and PO720 when I plugged in the reader.
Old Nov 11, 2022 | 09:13 PM
TPS, No big surprise there... and output speed sensor...... That one may be as simple as replace the sensor.... but, if your scanner can read live data, see if that one is available, and see what it has to say for itself.
Old Nov 11, 2022 | 09:20 PM
usmc123456789
I'll check it out and update the thread, thanks for the help!
