Ruptured fuel line
Old Sep 14, 2011 | 07:32 PM
OLE BLUE97's Avatar
OLE BLUE97
Default Ruptured fuel line
my high pressure fuel line ruptured about a week ago. obviously, i need to replace the whole line.
my questions are:
is it a specific line that i need? what size line? should i replace the fittings? any special tools i need?
and would it be easier to drop the tank, or remove the bed?
thanks in advance fellas!
Old Sep 15, 2011 | 04:44 AM
OLE BLUE97's Avatar
OLE BLUE97
Bump!!!
Old Sep 15, 2011 | 06:30 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Get a complete line from the dealer. There are 2 halves. The front half has the rubber end fixed to the steel.
Old Sep 15, 2011 | 10:18 AM
Only special tool you need is the disconnect tool. You can get 'em at the parts store. I believe it is 3/8ths for the fuel line.
Old Sep 15, 2011 | 11:29 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
I still can't figure that one out. I pinch both ends between my fingers and push it out. Thus, I once again prove that I kick-***.
Old Sep 15, 2011 | 01:54 PM
matty675's Avatar
matty675
i agree with v dub!
where did it rupture? the half that extends from the pump to the underneath the firewall is about $100, and needless to say a dealer-only item
Old Sep 15, 2011 | 04:16 PM
zman17's Avatar
zman17
$100 ? I replaced both halves on my 98 due to the nightmare I went through with the junk Carter fuel pumps. It wasn't even 50 bucks for both. Of course I guess it doesn't really matter, dealer only.
Old Sep 15, 2011 | 08:03 PM
Hans_GZP's Avatar
Hans_GZP
I'm replacing mine tomorrow. I'll be making my own though. I have a hydraulic flare tool that can make the disconnect fitting going to the flexible steel line. The pump end may end up just getting a fuel hose and some clamps. I'm doing the pump assembly as well on my v10. Stupid fuel filter design.
Old Sep 15, 2011 | 10:53 PM
matty675's Avatar
matty675
when did you replace yours zman?
damn STEALERSHIP!
good luck with the clamps...
Old Sep 15, 2011 | 11:09 PM
OLE BLUE97's Avatar
OLE BLUE97
so let me get this right....
the fuel line is a 2 piece, and since it ruptured right at the fitting above my tank, i only need to back half?
my fuel pump is on top of my tank right? thats where the fitting is?
does anyone have a picture of this?
sorry, i havnt dealt with this before and the dealer said the part is non returnable so i want to be right
